Raw Water Washdown Hose
I need a new hose and Tiara wants $300 for a 25' cockpit hose. I want to stay with the same type of rubber or PVC hose and not use polypropylene. Can anyone read a manufacturers name of either the raw water fresh water cockpit hoses? Thanks.
sorry I cant help you with this, but you said 'Tiara wanted..." I am trying to find a place to buy Tiara parts on line, I've been unsuccessful so far, so when you said 'tiara wanted', did you call them? is there a web site? etc TIA.
Try Jamestown Distributors...nice quality hose at a fraction of the price. It's a good quality coil hose. I too looked elsewhere when I heard the $300 figure from Tiara.
I have a 2006 36 Sovran. For the wash down I use a regular hose and bought a male fitting on line from http://quickcouplings.net You will have to search for the correct one to fit your connection. I think the fitting was $15.
John
36 Sovran, Cummins QSC
I have the following old numbers for Tiara Parts, they might still work.
(616) 394-7460
(616) 392-7163
I think I found the correct replacement hose http://www.coilhose.com/uploads/products/Page%2014.pdf . It has the straight tag ends on both ends as well as the coiled hose in different lengths and colors. It is called "Flexeel". It is sold as an air hose but can be used as a water hose. Cost is about $70.
kapdan
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 974 06-20-2026, 07:16 AM
  Water tank level sensors Final Pursuit 4 2,573 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,369 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,901 07-30-2025, 03:18 PM
  2900 open - a/c water pump not running North000 2 1,833 06-22-2025, 02:18 PM
