Tiara 3500 Express Platform With 450HP Cummins Sits lower than 370HP???
I have a 98 Tiara express with 3500 Cummins 6CTA engines (450 hp) and ZF302 transmissions and was told the other day by another Tiara express 3500 owner that my yacht platform was sitting lower from the water than his. His have the 6BTA engines which weight much less than 6CTA... so my guess is that it sits lower due to the weight of the engines? Or should I be looking at other things? There is no water intrusion on the boat, the platform feels solid and there are no soft spots...
You have to look at not just the weight of the engines, but fuel, waste, water, and “stuff” onboard. My boat has a noticeable difference in how it sits just depending on how much fuel I’m carrying.
It is my understanding, Tiara has specs on each boat they made. You could call them with your Hull number and find your draft specs for your boat. Since I'm looking for a 3500, I would like to know the draft of the 6cta also. The draft that the boat brokers state on their listings is always 4', which seems too much.
thanks for all your replies! According from this specs sheet, on the test unit, it says that the draft is 3'6".. Mine also has the same engines, transmissions and props specified on that test unit..
This is how it sits with full tanks:
Looks pretty normal to me. That swim platform looks perfectly level. If I was deciding whether my boat had a 3’6” or 4’ draft, I’d err on the side of caution and go with 4’.
  3500 Open deck lift piston drmiagi11 6 1,204 Yesterday, 10:03 AM
  [Tiara Sovran] Tiara 4400 PWC Lift on Swim Platform Feetwet 0 116 11-08-2026, 02:05 PM
Last Post: Feetwet
  Seriously considering a '98 4000 Express Cruiser... Have some questions... amajamar 3 1,150 10-28-2026, 01:07 PM
Last Post: Gustaf
  38 - 43' Tiara Open Comparision ClayPlatt 8 8,860 10-27-2026, 02:44 PM
Last Post: tk17
  Delaminated hull 2003 4000 express Steve Bosse 6 1,502 10-12-2026, 03:46 PM
