Cockpit Inspection Hatches
2 of the four hatches on the floor on the cockpit on my 2002 3100 Open are cracked and need to be replaced. I looked at it today and with the floor molded for the hatches how do you get some kind of tool under them to pry them out of the sealant they are bedded in? At first thought I am thinking about cutting the flange with a dremmel to get it started. I don't want to pry against the non-skip floor in fear of damaging it. Any guidance is appreciated.
One thing that will help is using Boatlife “Release” to soften and loosen up the sealant that is holding them in place. This was the only way I was able to replace the ones on my 33
I replaced all mine on my 98 31 Open. Heat is needed to soften the 5200. that an a really thin blade. Lots of patiance!
Thanks guys. So there is no silver bullet.
You can use commercial grade goo be gone to soften the 5200. Worked great when I had to replace an old transducer previous owner used 5200 to bed. Soaked it good and let sit for a day, soaked again, and the next day was soft enough to scrap out with a putty knife
Thanks will give it a try. Gotta love the strength of 5200, until you need to get it off.
Debond works ok for releasing 5200. Still takes a lot of patience and multiple applications to clean it all off, but it is a lot easier than using solvents.
  [Tiara Open] Cockpit bolster removal Rick B 0 93 11-14-2026, 12:15 PM
  Tiara 4200 Open Hardtop Hatches ClayPlatt 0 845 12-01-2025, 04:54 PM
Last Post: ClayPlatt
  [Tiara Coronet] Removing Cockpit Speakers Dave F 2 1,399 07-14-2025, 10:05 AM
Last Post: Dave F
  [Tiara Open] 2007 Tiara Cockpit Seat and bolster mounting brackets Roweje 0 811 06-28-2025, 12:35 PM
  Replacing aft cockpit seat covers - Sovran 3900 pallor 3 3,444 04-12-2025, 02:56 PM
Last Post: Skipperc3900
