crack in mid bildge
not sure if i postd in right subject area? noticed a crack in my mid bilge area, previous owner didnt do a very good repair, has anyone had this happen before and what recomendation do you have to fix properly, happy new year, thank you
Please supply some more pics of the surrounding area so we can get a better visual on exactly where this is. Looks like a floorboard that's glassed in over the keel which is not anything structural but would need to be ground back and any wet wood removed before properly repairing with fiberglass mat.
The crack appears to be in the hull as 2 thru-hull valves are in the picture. The crack may be cosmetic or in the hull which means that you may have to search for the crack on the hull exterior. If found, and the repair was not done properly, water may have infiltrated the hull coring which if wet needs to be removed for proper repairing.
Hull coring? not on that boat.
  1993 Tiara Sport 220 Fuel in the Bildge (Leaking tank) bradcool 1 975 01-21-2025, 08:50 AM
  water in bildge honest mark 12 8,494 07-22-2023, 11:32 AM
Last Post: honest mark
  [Tiara Open] Round crack in gel coat on hull side Crown Royal 2 2,031 05-10-2023, 07:42 AM
Last Post: Crown Royal
  crack in mid bildge honest mark 0 1,150 02-02-2022, 11:50 AM
  [Tiara Open] 3800 Window frame crack Tom_marshall@catellus.com 3 4,330 06-18-2020, 01:40 PM
Last Post: reeltimebrad
