Hatch and port crazing
Have 97 40’ express.  The three hatches polycarbonate is crazed.  Read where companies can replace the glass.  Any suggestions. Jack
IIRC, they’re Bomar/Pompanette so I’d give them a call. I recently got interior hatch trim from them, so I’m sure they either have or can make the glass for you.
My local glass shop cut new lenses and installed them for about $75 each. Otherwise order the lens from Pompanette/ Bomar and install yourself. Use a razor to cut the sealant, pop out the old lens, clean it all up and lay the new lens with recommended adhesive/ sealant. Mask everything off really well because the sealant makes a heck of a mess.
(01-03-2022, 05:47 PM)MC1600 Wrote: IIRC, they’re Bomar/Pompanette so I’d give them a call. I recently got interior hatch trim from them, so I’m sure they either have or can make the glass for you.
Thank you for your help..Jack
(01-03-2022, 09:35 PM)jclark003 Wrote: My local glass shop cut new lenses and installed them for about $75 each. Otherwise order the lens from Pompanette/ Bomar and install yourself. Use a razor to cut the sealant, pop out the old lens, clean it all up and lay the new lens with recommended adhesive/ sealant. Mask everything off really well because the sealant makes a heck of a mess.
Thanks for your help. Jack
I had the 3 hatches on my '92 3100 Open done here: SonSet Marine
They did a great job!
sonsetmarine.com
(01-12-2022, 09:00 AM)chuckkletecka Wrote: I had the 3 hatches on my '92 3100 Open done here: SonSet Marine
sonsetmarine.com
Thanks for help. Jack
  Source for rubber hatch stops sb in gp 3 2,569 11-14-2022, 10:27 AM
Last Post: sb in gp
  [Tiara Open] Engine room hatch lift thg885 4 6,666 09-14-2022, 04:59 PM
Last Post: HNS1
  Day Hatch Lock Rcc96 0 1,129 09-17-2021, 12:18 AM
Last Post: Rcc96
  4000 Express Hatch Hydraulics emarrero 9 8,505 08-31-2021, 09:04 PM
  [Tiara Open] Tiara 3100 Open Port hole window privacy shade Tgilbert 1 2,516 06-10-2020, 07:21 PM
Last Post: Tgilbert
