Tiara Open Tiara 3800 Open Transducer Replacement
Hello,
I'm looking to upgrade the electronics on my 2004 38 open. Looking to use Garmin electronics and an OEM transducer. Wondering if I am able to reuse the holes for the old transducer, or if I should leave in the old transducer and find a new location. Curious if anyone has done the same job and could provide feedback.
Thank you,
What transducer is currently installed? Where is it on the boat? How did it perform? How are you intending to use the new sonar--just depth finding? fishing? If fishing, what type(s) and what depth(s)?
I have helped a friend remove his transducer and install another thru the same hole. The biggest issue was the original was installed with 3M 5200. So after a week of softening with penetrating oil, we used a 2x4 and a large hammer and were able to jar it free. But reusing the same hole worked perfectly fine.
(03-08-2022, 08:19 AM)hiccup Wrote: What transducer is currently installed?  Where is it on the boat?  How did it perform?  How are you intending to use the new sonar--just depth finding?  fishing?  If fishing, what type(s) and what depth(s)?
The current transducer is an Airmar which has waterspeed, sonar, and depth. It is located directly next to the starboard side stringer underneath the engine. I could not find the model number, I will have to look through the manual and see if it is included. Intending to use the new transducer for cruising and light fishing, but would like to have some a more capable transducer to future proof the boat. Don't see a need for the sideview however.
(03-08-2022, 09:32 AM)Misdirection Wrote: I have helped a friend remove his transducer and install another thru the same hole.  The biggest issue was the original was installed with 3M 5200.  So after a week of softening with penetrating oil, we used a 2x4 and a large hammer and were able to jar it free.  But reusing the same hole worked perfectly fine.
Sounds like an ordeal. Thanks for the insight.
Airmar transducers usually have an ID tag on the cable, about 1-2’ away from the sensor. That should give you the mounting specs. I would definitely try to reuse the same hole.
(03-08-2022, 09:37 PM)jclark003 Wrote: Airmar transducers usually have an ID tag on the cable, about 1-2’ away from the sensor. That should give you the mounting specs. I would definitely try to reuse the same hole.
Got it.
Thank you!
The fewer the holes the fewer available leaks.
Look at the one you have and see if it is decent for your needs. If it is good then reuse it. Garmin makes a junction block that allows you to cut the wires and make it plug and play.
  2019 Tiara 34 LX stereo not working Bud Dieselman 1 1,943 10-01-2026, 07:47 PM
Last Post: icloud
  Refrigerator replacement for 1989 Tiara open/express Halekai 1 4,534 03-08-2026, 11:03 PM
Last Post: Longbeach3910
  2008 36 Open with Cummins Dosplays Afarneti 1 5,211 03-04-2026, 05:56 AM
Last Post: ken9090z
  2000 3500 Express Raymarine c120 Radar Replacement - Ohio River JMGCINCY2023 5 8,803 09-02-2025, 10:06 AM
Last Post: sluggo
  [Tiara Open] 1996 33 open gauges Mydiamond 1 5,586 08-18-2025, 10:57 AM
