2005 Tiara 3800 bait tank install
I am getting ready to install a 48 gallon Bluewater bait tank and need to cut in an inspection hatch in the deck between the aft fish box and the fuel shut off hatch. The deck appears to be about 2” thick, does anyone know what the composition of the the deck is?
If I'm following you, that is directly over the fuel tanks. There is also an aluminum plate molded into the deck intended to be used to reinforce the mounting of a fighting chair or rocket launcher that you will have to contend with. I believe the size & location of the plate is detailed in the user manual, if not then I would bet Tiara could supply it to you.
Thank you Hiccup, I have reached out to Customer service to see if I can get a size and location. I have confirmed that it is there by drilling a small hole, I am hoping to work around it and not have to cut through it. My plan is to cut in a 7” x 11” inspection cover then have a plywood cleat above and below deck bolted together so that I have no deck fasteners.
Confirmed from Tiara the plate size is 21” x 21” x 1/2” aluminum plate. Might have to offset the tank a little
  1995 3500 Express LFP/Inverter Install penneyma 0 690 09-09-2026, 07:09 PM
Last Post: penneyma
  Adding a Live / Bait Well to my 3200 Open ove.schuett@comcast.net 1 1,568 07-07-2025, 06:55 PM
Last Post: Woodworker2001
  Factory Tiara Classic Hardtop jmk 33 50,416 06-08-2025, 09:22 AM
Last Post: Craig Dunlop
  4000 Express tender/davit install Jack Aperio 7 6,204 05-31-2025, 09:05 AM
Last Post: Jack Aperio
  4000 Express New Generator/Gen-Sep Install Jack Aperio 2 2,237 03-06-2024, 06:04 AM
