09-30-2014, 05:29 PM
I have a '97 2900 Open. I am getting condensation along the carpet at the forward step to the berth in the cabin. I have narrowed down the source to the AC unit as I only get the the moisture after running the unit. I assume there is a clog from the Mermaid AC unit to the sump pump under the two steps in/out of the cabin. There is no moisture around the unit and I cannot find a "drip tray".....Any ideas of how to fix this issue?
Second question - The AC unit seems to be very loud while running. I had a cruise air unit in my last boat and it ran much quieter. I talked to Mermaid and they said that there should be a foam gasket under the drip tray to absorb some of the sound but I have not been able to locate or verify if I have the gasket in place.
Any help would be greatly appreciated.
Thanks!
Graydon
Thanks!
Graydon
