Tiara Sovran Looking for a new mother board for the A/C in the master cabin.
hi there !
owner of a Tiara 43 Sovran 2007.
l need to replace the mother board of the a/c - whose production has been apparently discontinued 4 years ago - of the master cabin.
Any kind suggestion where to start to look for it (new ore a reliable used one) ?
Giampiero
What is the model number on the unit that you have?  And manufacturer, is it Dometic? You will need that information
Citimarine.com has replacement boards for legacy Marine Air Systems, Cruiseair and Dometic. As previous post mentioned you will need make and model number. You may also need to give them some information on your thermostat, depending on which unit you have as many boards require a specific model of thermostat.
(08-08-2023, 08:41 PM)jclark003 Wrote: Citimarine.com has replacement boards for legacy Marine Air Systems, Cruiseair and Dometic. As previous post mentioned you will need make and model number. You may also need to give them some information on your thermostat, depending on which unit you have as many boards require a specific model of thermostat.
many thanks for your - and donaldjames - replies,
here are the details of the a/c on the containing box (anyway photos of the mother board are also available):
  • Marine Air Systems / manufactered by Dometic
  • product # : 201 - 411160
  • s/n # : 62456965
  • model # : CSD6KZ50/1 - 41710PVBX
  • shop order: 078642
  • cap. (BTU) 6000
  • voltage/hertz 220-240/50
  • PH 1
  • max fuse 10
  • min fuse 7
  • FLA.COOL 4.1
  • FLA HEAT 4.8
Elec. data above based on 220/50 HZ
I.O. control; 417 Refrigerant;
10' Plug Harness
Vertical Electrical Box
  • s/n # : 62456965
  • cap. (BTU) 6000
  • PH 1
  • max fuse 10
  • min fuse 7
  • FLA.COOL 4.1
  • FLA HEAT 4.8
10' Plug Harness
Contact Raphiel at Yachtaid in Florida. He will be able to get you the circuitboard I believe.
+1 (786) 621-3010
problem solved, thank to your advices.
order delivered on thursday, arrival in Rome on following monday late morning.
Citymarine: excellent communication and timely delivering.
  [Tiara Open] Location Of My Cabin Air Conditioner and Filter Dry Foot-Wet Foot 10 12,861 09-17-2021, 09:02 AM
Last Post: Misdirection
  AC condensation along carpet in cabin & loud AC unit gmoss001 0 2,408 09-30-2014, 05:29 PM
Last Post: gmoss001
  Cabin Fumes & AC Unit Titan17 4 9,009 09-10-2013, 03:36 PM
Last Post: justrollin
