Broken Capt Seat
I have a 2002 4100 Open and the powered captain seat has broken plastic blocks.  It appears to be the part the seat is mounted to and slides fore and aft in the seat rail.  Can you please advise where I can purchase these?
Thanks in advance!
Funny you should bring this up because mine broke a couple weeks ago. It was promptly added to the "winter list" for the off-season, but I've done some research in the meantime. There doesn't seem to be a supplier where you'll be able to just go buy the parts. According to my research, our best bet is to disassemble then find some plastic which others have said is easy enough to recreate with basic basement tools.
Good luck! If you find an easier solution, please be sure to report back as I will promptly follow your lead.
Thanks for the information.  I'll research and send a note if I locate one.
Thanks,
Tim
(07-12-2022, 12:17 PM)MC1600 Wrote: Funny you should bring this up because mine broke a couple weeks ago.  It was promptly added to the "winter list" for the off-season, but I've done some research in the meantime.  There doesn't seem to be a supplier where you'll be able to just go buy the parts.  According to my research, our best bet is to disassemble then find some plastic which others have said is easy enough to recreate with basic basement tools.
FYI, I called Tiara and they had them in stock. $149 a set.
Best,
Tim
What exactly did you get from them?
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,773 05-12-2026, 10:18 AM
  [Tiara Open] 2007 Tiara Cockpit Seat and bolster mounting brackets Roweje 0 812 06-28-2025, 12:35 PM
  Replacing aft cockpit seat covers - Sovran 3900 pallor 3 3,451 04-12-2025, 02:56 PM
Last Post: Skipperc3900
  [Tiara Open] Jump seat won't lock in place jsheerin 2 1,569 11-13-2023, 12:48 PM
Last Post: jsheerin
  Searching for Fold Down Bench Seat for 3200 Open. sharon@coastalcm-llc.com 3 2,859 07-29-2023, 07:34 AM
Last Post: kathyandgene@verizon.net
