Winterizing Lift Muffler on 4000 Express
The mufflers in my 4000 have no drains. I find it kind of wasteful to push 30gals of antifreeze through each engine for what should take 5. If I pull the inlet hose, will the mufflers drain enough to prevent having to fill them with antifreeze?
(10-07-2022, 09:46 AM)MC1600 Wrote: The mufflers in my 4000 have no drains. I find it kind of wasteful to push 30gals of antifreeze through each engine for what should take 5. If I pull the inlet hose, will the mufflers drain enough to prevent having to fill them with antifreeze?
I have the same boat and have the same concerns about pushing 15 gallons each through the exhaust.   How would removing an inlet hose help drain them?  I think you mean remove exhaust hose?  If so, good luck reaching it...lol
The amount of antifreeze is probably overkill.  I assume there is lots of room for expansion but it looks like it would be a nightmare to have to replace one of those mufflers so I will just keeping using antifreeze.
I just bought a 3500 express and also concerned about the amount of antifreeze to use. I'm planning on using 8 gallons per engine.
I hope more members chime in with their experience.
Thanks August. Guess the safe/smartest bet is to just keep biting the bullet and paying for the antifreeze.
I don't understand the post. Why are you wanting to fill the muffler with anti freeze? When i winterize we run the engine and start pouring AF in until we get pink out the exhaust. That is usually about 6 gallons in our case. Am i not understanding something?
Cummins 5.9's in our 3200
Our boats have massive mufflers that hold a lot of water. I think I used about 20gal/engine last year before getting pure antifreeze out the back.
  Tiara 40 Express 2003 - Removal of Cleat saywhen 2 454 11-14-2026, 05:25 PM
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 442 08-21-2026, 02:33 PM
Last Post: hmtrerice
  2000 3500 Express Windshield Wiper Blade Replacements JMGCINCY2023 5 3,163 04-19-2026, 06:48 PM
  Tiara Express Battery Charger Replacement Svdb12@chartermi.net 0 757 09-07-2025, 11:19 AM
  2001 40 Express - Windshield Washer Will Not Stop bruce@bigrivergroup.com 1 874 09-02-2025, 06:19 PM
