Tiara Open Engine Room Switch
2002 38 Open
For the helm,I need a new engine room lights switch...not just the cover. It has a small square that illuminates white when on. I would like to have the exact same one I have now for an idiot proof install.
I’d start with these guys:
https://www.otrattw.net/home.php
Most if not all switches on my 2003 38 Open are from Carling Industries... I've needed several over the years and found using the Carling configuration tool easy. Once you have the part number you can google where to purchase. Worked for me.. Here's the link to the Carling switch configuration tool (use "configure a part" button).
https://www.carlingtech.com/rocker-switc...ies-ii-iii
Looks like you pull the panel from the outside to replace it rather than bringing the entire helm back.
Agree, pull the panel from the outside but there is a challenge with that.. After removing the panel screws you need to be very careful in lifting the panel out as the wires are relativity tight/short... 2nd challenge is removing the old switch as the hold-downs for the switch are difficult to release. Good luck
[attachment=1100]
West says this one is discontinued and I can't find the exact one on the other sites suggested. Does anyone have a link or a replacement? The white square is illuminated when it is on.
The picture in your post I don't believe reflects the original switch installed by Tiara when the boat was built. Believe the attached is the original switch and should be the same/similar with all others on the panel. M2C
.pdf   V-Series-II-III_datasheet-V1D1BC0B-CMB00-000.pdf (Size: 1.78 MB / Downloads: 10)
Reel Magic, That's what Tiara said. I just ordered one like I have now from New Wire.
Thank for the usual excellent help.
Got it done today. Amen to the hard to remove old one comment.
  1988 3300 Open - Voltage drop when lowering engine hatch or honking horn Pluto 3 1,524 03-24-2026, 09:46 AM
  DC Panel Volt/Amp Seclector Switch Replacement Peave 4 1,728 11-07-2025, 02:50 PM
  Main Panel Switch needed or 1997 40 mid cabin express Salty0ne 0 873 03-28-2025, 09:44 PM
Last Post: Salty0ne
  2007 39000 Sovran Engine Hatch Won't Lift Kevin Spellman 3 3,670 08-04-2024, 03:16 PM
Last Post: rcwiegand
  Nav/anchor Light Switch Joeboch348 5 3,340 06-29-2024, 09:55 AM
Last Post: roboh20
