GFI 3900 Sovran
The starboard side outlets on the boat are inop. The switch on the panel is on. Is there a GFI switch, other than the one on the helm outlet, located anywhere on the boat?
(11-29-2022, 03:00 PM)Bdouglass Wrote: The starboard side outlets on the boat are inop. The switch on the panel is on. Is there a GFI switch, other than the one on the helm outlet, located anywhere on the boat?
Our owner's manual was wrong and our GFCIs were behind a drawer next to the electrical distribution panel.  Had to remove the drawer to see them and reset the culprit!  Perhaps your will be more help.
If not, try head cabinets, galley cabinets too, that's where they were on our Sea Ray and Grand Banks in the past.
Good luck.
2020 53 Fly
Gulf Coast Florida
A member reached out and told me they were to the left of the tv in the tv room. Boom….there they were. It was the issue. All well now.
I had the same issue on my 06 38 open, besides the breakers that are labeled for the outlets on the electrical panel, I found three blind (no plug in holes)  GFCI’s behind the main salon seat cushion.  On my boat it’s to the left of the breaker panels under the stairs.  First pull the seat cushion and underneath there should be a removable panel behind which you’ll find  the battery charger
And the three blind GFCIs.
  2006 Tiara 3600 Sovran Stereo Question. Final Pursuit 0 839 10-25-2025, 03:53 PM
  Inverter- How to use and location 39 Sovran August Rush 3 1,997 09-02-2025, 09:49 AM
  2006 3600 Sovran Generator Battery location Final Pursuit 0 921 08-09-2025, 07:49 AM
  2007 39000 Sovran Engine Hatch Won't Lift Kevin Spellman 3 3,720 08-04-2024, 03:16 PM
Last Post: rcwiegand
  [Tiara Sovran] 2004 52 Tiara Sovran Salon Charles Ind. Master Controller ACMC 50I-1 Knot On Call 2 2,366 05-21-2023, 08:32 AM
