44 Coupe - change to different anchor?
I own a 44 Coupe. The anchor that comes with the boat from Tiara is more of a fair weather "lunch hook".  Does anyone have experience with other anchors more suitable for longer cruising trips where anchoring out in stronger winds may be needed? For example, a Mantus M2?
I want to buy a more suitable anchor but am concerned that it won't fit in the 44's anchor stowing track/bow penetration.
Rick
(11-29-2022, 03:06 PM)kysloc4 Wrote: I own a 44 Coupe. The anchor that comes with the boat from Tiara is more of a fair weather "lunch hook".  Does anyone have experience with other anchors more suitable for longer cruising trips where anchoring out in stronger winds may be needed? For example, a Mantus M2?
Rick
What makes you think the anchor you have is just a lunch hook?    I run the stock anchor on my 40 express (its a Danforth Plow) and it holds incredibly well...
If you were going to make change I would go with changing to an all chain rode if the boat doesn't have it already.   According to the buyers guide your boat should have a Lewmar DTX 37 lb anchor.   I am not sure what conditions you be anchoring in, but thats a big anchor.   The others out there probably wont perform any better unless you have ground condition issues.  The plow style anchor performs well in most bottoms but there are anchors that will do better in certain conditions than others.
Rick
Thanks for the insight. This is my second Tiara, and I am a big believer in the engineering of their boats. Having said that:
a) Yes, I have the 37# Lewmar as on the Tiara spec sheet (I bought the boat new).
b) We are marina people - only time we would anchor (other than for lunch) is if we were caught in a storm and needed to duck into a cove to wait it out. In New England (our home) that's easy - there are lots of marinas to duck into. In the Bahamas (where we are going this spring..Abacos and Exumas), I am concerned that the OEM actor would not hold/grip in the hardpacked sand and marinas seem to be a lot fewer/far apart. Mantus anchor (for one) recommends 55# anchor for winds up to 30 knots for my size boat.
Hence my desire for a heavier anchor. The online video demos of Mantus (granted, video made by Mantus) show that it holds better than a regular Plow. So if I'm gonna spend a lot of money for heavier anchor I'll go with the Mantus.
As far as the rode: mine is 40 ft chain and then rope. I will look into what's involved to change to all chain (shouldn't be hard since all-chain is a Tiara factory option).
The Mantas anchor is far superior to other anchors. I have run the Abacos many times and when I meet the cruisers over there they are big into their anchoring system. Most I have spoken with do nothing but rave about the Mantis.
An all chain rode is preferred. The chain allows a shorter scope for most times and gives a better set with no fear of chafing on anything. Make sure you put in a shock/snubber line from a cleat to give it some stretch. Chain doesn't stretch and will cause all sorts of problems in a heavy wind or sea.
  need to replace solenoid for the windlass how to I get my fat ass into the anchor sluggo 3 2,139 04-19-2026, 06:46 PM
  Tiara Coupe - Sunroof now closes, but hisses when closing - does this sound right?? ericcrews 1 1,111 06-03-2025, 07:32 AM
Last Post: TBM900
  Power issue livewell and oil change pump smagistro 1 876 04-22-2025, 06:07 AM
  [Tiara Open] Anchor Rode Compartment Drains nylakeshome 2 1,583 11-22-2024, 05:40 PM
Last Post: nylakeshome
  [Tiara Open] 1989 Pursuit (Tiara) 2800 Open Thru Pulpit Anchor Hardware cmgtrumpet 0 878 07-03-2024, 12:29 PM
Last Post: cmgtrumpet
