50/53 Coupe and Fly Owners Group
[color=var(--primary-text)]Looking for specific 50/53 coupe/fly information. Has any one solved a water intrusion issue, both port and starboard aft corners? I get an intrusion when running, it appears to be where the seam between the bottom and top portions of the hull is joined. I need to do some more testing, but it like some intrudes when washing the hull as well.[/color]
[color=var(--primary-text)]So far I have dried both sides and ran all systems in the slip for a few days (air conditioning, fresh water both on city hose and freshwater pumps, etc.) Dry. Took a one hour cruise and hosed the boat off when back in the slip and water present. I can see "stains" coming from this seam leading me to believe it is the culprit. Boat is a 2020, any chance this would be covered under the 5 year hull warranty?[/color]
[color=var(--primary-text)]Thanks for any and all actual experience you might have had with a similar issue.[/color]
2020 53 Fly
Gulf Coast Florida
  Tiara Coupe 44 HNS1 2 3,521 01-28-2026, 03:57 PM
Last Post: tharvey
  Tiara Coupe HNS1 3 7,629 08-18-2025, 01:51 PM
Last Post: Motus
  2022 39 Coupe Sunroof timstraker 0 1,699 08-12-2024, 12:25 PM
Last Post: timstraker
  39 coupe engine access Fixinbones 5 8,038 08-12-2024, 12:21 PM
  Considering the purchase of a 39 or 44 coupe. Engine room access is a concern South Sound Steve 1 3,376 04-24-2024, 02:24 PM
Last Post: HNS1
