Waste hoses u
I’m in the process of changing all my waste hoses.Some are straight forward but the ones to the head and the deck plate seem tough to access. Boat is a 2003 38 open.Any tips appreciated.Bill
Not on a Tiara, but I helped a friend replace a waste line on his boat. He got a double end barbed hose fitting and attached the new waste line to the old one. I believe he used some adhesive on the barb since he couldn't put clamps on it. Then, while I gently pulled from the engine room, he was gently feeding the new line from the head. This allowed for both removal and installation at the same time.
Perhaps something like that would help?
For the one to the deck fitting, I’m not sure how you’d do it without removing the deck fitting itself. Use the hose barb method mentioned above and pull it through.
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,352 09-17-2025, 05:52 AM
Last Post: Splendor
  1993 4300 open waste and water level indicators bpro 1 3,322 08-07-2023, 08:31 AM
Last Post: esf
  Waste Pump out switch Herrema4 2 4,210 09-09-2019, 04:09 PM
Last Post: Herrema4
  Fresh and Waste Water Gauge Tom Gaertner 8 10,869 12-31-2016, 07:48 PM
Last Post: sbw1
  2900 Waste Tank Russf 13 16,854 06-16-2015, 02:17 PM
Last Post: veromon
