06-25-2023, 09:16 PM
Having trouble keeping water from coming in the bottom of the center windshield. The bottom 2 drain holes are open and I used the flat gasket & L gasket on the right, left, & bottom. L gasket corners are mitered and there is not any opening cut in the gaskets by the drain holes. Based on Tiara's info and prior posts believe my install is correct?
Noticed with the new gaskets the bottom of the center windshield was about a 1/4" raised from being flush. The twist locks would not even come close to turning on. Started cutting away gasket piece by piece from the top to find where it was potentially binding...it improved only slightly as I went and ended up removing all of the L gasket just to prove it would lay flush without the gasket. That worked but now looking for some guidance before putting L gasket back on. The only other noticeable potential issue was the left-right alignment of the center windshield is off maybe an 1/8".
Any suggestions?
Thank you!
Brad
Any suggestions?
Thank you!
Brad
