Tiara Open Open 4100 change from AGM to Lithium?
The AGM's o0n my 4100 open are Northstar AGM31's and NS is no longer in business.    The batteries charge up nice but can't hold the charge for more than a couple/few hours with the inverter turned on.   Since NS has been out of biz for four years, I am assuming the batteries are older than that.   Wondering is a switch to Lithium would make sense.   Able to do this without having to change my charging system or is it easier to just replace the AGM's with Interstate or some other brand.
It's definitely easier to stick with AGM. Switching to LiFePo4 batteries will require a full investigation of your charging and electrical system and potential changes to both the alternator/regulator and shore power charger, depending on how it's setup now.
With that said, the performance from the lithium-based house systems are night and day better than what you get from a typical AGM install. It's a pain but worth it for those of us who use a lot of energy while away from the dock.
(07-10-2023, 07:25 AM)hiccup Wrote: It's definitely easier to stick with AGM.  Switching to LiFePo4 batteries will require a full investigation of your charging and electrical system and potential changes to both the alternator/regulator and shore power charger, depending on how it's setup now.
-------Thanks.   It's a big investment either way, so want to make sure I do it right
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 1,620 07-15-2026, 08:06 AM
  2001 3100 open generator runs but doesn't generate electricity lakesidevu 5 2,950 11-14-2025, 01:01 PM
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 2,951 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
  [Tiara Open] 1994 Tiara 31' Open Charging and Inverter problems: mholts13@yahoo.com 3 4,459 11-18-2024, 10:51 PM
Last Post: Polesetter
