Lack of kitchen faucet water pressure
I’ve got good pressure in all my other sinks and the shower except for this faucet in the galley. I’ve pulled the little filter off that sits right in the faucet and cleaned it to no avail. Also with the filter out and the sink on there still is not much pressure. This is a hansgrohe faucet on a 39 coronet.
(06-29-2024, 10:07 PM)d5dekeyser Wrote: I’ve got good pressure in all my other sinks and the shower except for this faucet in the galley. I’ve pulled the little filter off that sits right in the faucet and cleaned it to no avail. Also with the filter out and the sink on there still is not much pressure. This is a hansgrohe faucet on a 39 coronet.
Check the connection under the sink where the faucet plumbing joins the boat plumbing.  There is typically a small screen in there.
2020 53 Fly
Gulf Coast Florida
I have a 2007 3600 open, and in my Tiara Owmers manual, it says there is a fresh water filter behind the panel under the sink that should be replaced every so many years. Kind of like a refrigerator filter. It does say it is behind the panel under the sink, and the panel it’s screwed in. Maybe check your owners manual to see if you model has that same filter.
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 943 06-20-2026, 07:16 AM
  Water tank level sensors Final Pursuit 4 2,527 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,319 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,857 07-30-2025, 03:18 PM
  2900 open - a/c water pump not running North000 2 1,785 06-22-2025, 02:18 PM
