2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location
The Cockpit  Fridge and adjoining plug  outlet worked on our new to us 2000 3500 Express two weeks ago when the survey was done.  After trucking it down from MI, neither work.  Everything else on the boat operates.  Is there a hidden breaker or something we have not been able to find?
Thanks, Mike
Mike - is there a GFI upstream of the plug? or is there a GFI on that plug behind the refrigerator?  Good luck.
Agree with above, likely a GFI outlet has tripped.
(08-06-2024, 06:43 PM)hiccup Wrote: Agree with above, likely a GFI outlet has tripped.
Thanks, we'll be looking at those locations and some other places with my borescope camera.  I'm thinking a GFI popped when she got plugged to the dock post after delivery.  We were not there and last week the Post kept popping it's breakers.  Marina is replacing this week.
Mike
We got her out on the river, amazing boat.  I've checked every GFI I could find including the engine room and all tested live.  Next weekend we'll pull the fridge out as it has to be plugged in somewhere.  Since it is probably the original and it will be out, might as well replace it.  Hope that is where the issue is.
Mike
We solved the issue.  Using a bore scope going through a small hole under the helm seat through the wall behind the cockpit fridge, we found a GFI plug behind the fridge.  A previous owner had installed a vent plate on the starboard side of the fridge.  Not much room but we got it off and we're able to gain access to the GFI behind the fridge.  We reset and it all works.  It probably got josteled during transit from Lake St. Clair to the Ohio River.
Mike
  3500 Sovran trimtabs drprunner 0 93 11-14-2026, 03:44 PM
Last Post: drprunner
  [Tiara Open] Cockpit bolster removal Rick B 0 93 11-14-2026, 12:15 PM
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 520 07-28-2026, 06:28 AM
Last Post: Tiara45
  2000 3500 Express Windshield Wiper Blade Replacements JMGCINCY2023 5 3,139 04-19-2026, 06:48 PM
