4000 Express - Manually Open Garage Hatch
Help,
My garage door closed and now will not open. Is there a way to manually raise the door? I think the fluid is low. The catch is that to access the hydraulics you must open the garage door.
Thanks,
John
"My garage door closed and now will not open. Is there a way to manually raise the door? I think the fluid is low. The catch is that to access the hydraulics you must open the garage door."
Yessir.  Open the round ports that are in the aft-facing settee & disconnect the pins that hold the hydraulic system to the door & you can open the door by hand.
(11-09-2024, 12:45 PM)bruce@bigrivergroup.com Wrote: "My garage door closed and now will not open. Is there a way to manually raise the door? I think the fluid is low. The catch is that to access the hydraulics you must open the garage door."
Thanks! You're a life saver. Marine tech wanted to put boat on the hard to repair. Tiara has thought of everything.
We have a 3500 Express, I unbolted the top hinges and got the trunk open.
Mike
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 432 08-21-2026, 02:33 PM
Last Post: hmtrerice
