Water in Salon bildge
I've recently discovered water in salon bilge not coming from the shower pump any suggestions would be appreciated.
(06-30-2015, 05:19 AM)getreel Wrote: I've recently discovered water in salon bilge not coming from the shower pump any suggestions would be appreciated.
I would do a search on the forum; this issue came up a few times.  I believe Cpt. George had some good comments on it.  If I recall a lot of people say it comes from the rub rail.  There was a good suggestion regarding putting powder in the bilge to see where the water is running from.
I get it in my mid bilge as well, but I believe my issue is from a leaky shower sump and a pump that can't keep with with the water from the sink/shower.
That's the best trick. Talc powder will show where it's coming from. It's trial and error. Capt. George
Thank You, I'll give it a try
I also found that the sink drains or water feeds to either the head or galley sink may be leaky.  Both these feed into the mid salon bilge.  Not a lot of water but some.
Good luck
Also check that the fittings on the fresh water tank are not cracked or loose...  Do you notice it more after you fill fresh water etc?  Is it worse when it rains etc?
you may also want to check the ac line it could be broken and dripping into the bildge
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 757 08-17-2026, 05:31 PM
Last Post: Bford100
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,805 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,928 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 564 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 679 11-21-2025, 05:53 PM
Last Post: lenoah
