Crusader xmission cooler
I have a 2005 Tiara 2900 with Crusader 6.0L engines. The transmission oil cooler for the starboard engine is mounted next to the hull and is extremely difficult to change or so it appears. I cannot even see it. Any suggestions on how to go about getting at the cooler and changing it.
(07-23-2016, 08:56 PM)Russf Wrote: I have a 2005 Tiara 2900 with Crusader 6.0L engines.  The transmission oil cooler for the starboard engine is mounted next to the hull and is extremely difficult to change or so it appears. I cannot even see it. Any suggestions on how to go about getting at the cooler and changing it.
I just did mine. You just have to lean over the engine and stretch to get to oil lines and two mounting bolts.
Thanks Scurvey. Its nice to know that it can be done.
Deck Hand, When you remove the oil cooler, don't throw it away. Take it to a radiator shop and they can clean it out ( about $35.00), Cheap compared to $380.00 for a new one, even if you keep it for a spare.
  [Tiara Open] Crusader MP7.4L Air Inlet Tube mikezacharias 6 3,215 04-28-2026, 06:17 PM
Last Post: bob4144@icloud.com
  [Tiara Open] Flushing coolant and replace crusader 454xl Mydiamond 0 1,027 09-20-2025, 06:41 AM
  Crusader 502XLI ECM Harness 10 Amp Circuit Breaker tripping MGTTF 2 1,588 04-27-2025, 05:11 PM
Last Post: MGTTF
  2005 3200 Open w/ Crusader 8.1 - Fuel line size? tyrentz 1 1,214 12-02-2024, 09:55 AM
Last Post: Hooper
  2005 Crusader 8.1 Exhaust Elbows Matta0413 1 1,656 10-05-2023, 04:50 PM
