2006 Tiare Sovran 3600 how do I remove the steering wheel?
Somehow I think I bent (warped) the steeling wheel, and I would like to have it straightened.  I got the cap off, and then there is a nut, I got the nut off, but nothing.  I cant tell if there is a retaining ring, or snap clip or not that needs removed.  Someone suggested beating on the nut and it should pop lose.  So Before I try that, I thought I would ask, and see if there is something simpler.  TIA
(it is one of those pretty big (2'?) in diameter wheels with wood on the outside)
(01-23-2017, 02:18 PM)sluggo Wrote: Somehow I think I bent (warped) the steeling wheel, and I would like to have it straightened.  I got the cap off, and then there is a nut, I got the nut off, but nothing.  I cant tell if there is a retaining ring, or snap clip or not that needs removed.  Someone suggested beating on the nut and it should pop lose.  So Before I try that, I thought I would ask, and see if there is something simpler.  TIA
I've removed mine, after removing the center bolt, you need a puller, I got one at a local autozone. Mine was the
kind with 3 adjustable grabbers and a center bolt, you adjust it and turn the bolt
on the center, it came off easily.
Mine was similar to this one:
http://www.autozone.com/test-scan-and-sp...ckfit=true
You put the center bolt (with the point) in the center of the bolt (that you removed the nut from), then adjust the grabbers around the stainless ring, then using a wrench turn the center bolt.
Basically like this:
http://continuouswave.com/whaler/referen...00x450.jpg
Thanks!  so to be clear you have the same boat??  TIA
Yep!
Yep!
Thanks again!  I'll stick it on there and try and not worry about the little thing I think is some sort of keyway.
Yep!
The piece of metal, "the key" stays in the square groove in the shaft and wheel hub. I replaced my wheel with a new one, and the new wheel came with a new key. Make sure you don't drop and/or lose the key. It will come right out no problem with the puller.
  3500 Sovran trimtabs drprunner 0 119 11-14-2026, 03:44 PM
Last Post: drprunner
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 589 08-31-2026, 10:34 AM
Last Post: Herrema4
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 756 08-17-2026, 05:31 PM
Last Post: Bford100
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 538 07-28-2026, 06:28 AM
Last Post: Tiara45
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,926 02-23-2026, 11:01 AM
