11-12-2012, 06:48 PM
Understood. Will let you know how it all goes...again, thanks.
(11-09-2012, 09:42 PM)Uhehner Wrote: I still don't understand the fuel consumption and carburator issue yet but get the engine running correctly first. I would purchase a new distributor module. This was my guess on 11/9. Next, be sure to set the timing correctly using a timing light. If you set it too low, your mileage goes down. If you set it too high ( degrees before TDC ) you will burn up a piston. Time both engines. Capt. George
| '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL | Showtime | 3 | 1,618 |
05-23-2026, 02:12 PM Last Post: Capt. Paul |
| [Tiara Open] Tiara 31 open crusaders getting when WOT | aliyilmaz | 5 | 6,252 |
03-03-2025, 07:40 PM Last Post: Mydiamond |
| [Tiara Open] Repowering a Tiara 3100 Open with 2 outboards | drake | 2 | 3,361 |
08-21-2024, 09:09 AM Last Post: cp4000 |
| 39 Coronet Cummins generators issue | d5dekeyser | 4 | 3,751 |
07-28-2022, 08:53 PM Last Post: Sans Peur |
| [Tiara Open] 2006 Tiara 42 Open Transmission | Kphillips | 1 | 2,011 |
07-12-2022, 09:00 PM Last Post: jclark003 |
| 1 Guest(s) |
