Replacement TV for 3200 Open
Anyone replace their TV? What's a good one?
I replaced mine on my 2006 36 Sovran with a Jensen.  The ones on the boat were 12 volt so I could not use a standard one form Best Buy.  I got it through Hodges marine.  It fits where the old ones were.  Here is the link.
John
36 Sovran, Cummins QSC
I went through the same thing with my 2006 Sovran, but I also learned a little about TV's.  It seems many of today's TV's run on 12 VDC and you can get them at Best Buy.  all you do is look at the specs.  If they are 12vdc, just cut the cord to the power supply and wire into where the old one was!! Biggest problem is, in or around 2006 the TV's for over the air signal switched to Hi Def.  So you either need a new TV that gets hi def, plus an antennae that receives hi-def, or you can use the old ones with a converter.
(06-13-2016, 09:21 AM)johnhesch Wrote: Anyone replace their TV?  What's a good one?
Majestic makes a 12 volt that fits the opening of a 3200 perfectly. No need to do any wood work modification. The company makes cvs for the boating and RV industries.
  38 open bathroom recessed light bulb twilson0929 3 486 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 386 08-18-2026, 02:11 PM
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 358 07-25-2026, 09:15 AM
Last Post: roboh20
  2001 38’ Open interior table base removal twilson0929 3 765 07-07-2026, 08:13 AM
  Freezer Replacement for 40' Tiara Reprise1 4 1,709 06-09-2026, 02:28 PM
Last Post: fuzzy
Replacement TV for 3200 Open00
