WEMA gauges waste/water
2001 38 open
When the WEMA tank monitor is pressed to either waste or water the gauge does not register at all. Does anyone know what the proper sending units are for the waste & water tank
Thanks in advance
[-] The following 1 user Likes OurHighLife's post:
bsause (05-23-2020)
Are you sure the sensors are bad? I've had similar problems with both readings. I found many times I needed tap the gauge while holding the appropriate button (fresh water or waste level)... Another thing I did was to pull the sender for the waste tank and found it clean but it doesn't reach the bottom of the tank...I've included a diagram showing the depth my sender goes down in the waste tank so when the tank is less than 4" full it shows empty. M2C.
bsause (05-23-2020)
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,536 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,656 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 460 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 569 11-21-2025, 05:53 PM
Last Post: lenoah
  [Tiara Open] Water under Quartz flooring in head benmaser 0 647 06-16-2025, 02:24 PM
Last Post: benmaser
WEMA gauges waste/water00
