Tiara 3100 shaft seals
Looking to convert to PSS dripless shaft seals and get rid of the packing setup.
Any idea on the tube size and shaft size?
I know, I can crawl in the bilge and inspect the shaft size but the tube size, I don't think I can get an accurate measurement without pulling the hose off(the boats in the water). Was hoping the tube boot had the size on it, but to my luck, it was cut between markings.
Any help is appreciated, as I'd love to get rid of the drips all together. Pricey conversion but looks like a world of difference.
1986 tiara 3100 open crusader 454. FWC.
Sent from my SM-G900V using Tapatalk
Check out GFO Gore Tex shaft packing on eBay. I put that stuff in about 5 years ago and have not needed to adjust them since then. It's not like the old flax packing and a heck of a lot cheaper than installing PSS seals. I know everyone is happy with PSS but it's a job installing them. While you are down there consider adding splash guards around the seals. Just take a 3" or 4" x 8" hose and cut it lengthwise and put a clamp on it . That way if you do have some drips they do not spray all over at high speed. Capt. George
Thanks george, I do have the GFO in, I have one shaft that's virtually dripless, the other I haven't adjusted yet this season. I don't think last season I got it 100 percent adjusted on the stbd. My port, good and runs cool with almost zero drips.
I just like the idea of a dry bilge minus deck water that gets in while washing..
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 473 08-17-2026, 05:31 PM
Last Post: Bford100
  Freezer Replacement for 40' Tiara Reprise1 4 1,626 06-09-2026, 02:28 PM
Last Post: fuzzy
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,326 05-22-2026, 06:41 PM
  Tiara 3700 Open Runaway 2 1,211 04-20-2026, 04:26 PM
  [Tiara Open] 93 3100 fuel tank sending unit. Joeboch348 1 540 02-18-2026, 09:15 PM
Tiara 3100 shaft seals00
