High fuel consumption
I have a 1986 2600 Continental with a 260 Mercruiser engine 5.7 the boat takes forever to get on plane and is using way too much fuel can someone tell me the recommended prop size I know how to use the trim tabs I know how to use the outdrive trim I'm not happy with the fuel consumption
I'm not sure of the recommended prop size. I'd recommend calling Tiara customer service. However, I did a search on The Hull Truth and I think what your experiencing is common for that boat with a single screw.
https://www.thehulltruth.com/boating-for...uiser.html
Thanks deck hand I read that before I think someone else changed the prop I'll start there
What is your RPM @ WOT.  Should be 4200-4600 with boat trimmed out.  Less than 4200 RPM & your are over propped.  More than 4600 RPM and you are under propped.   I own the same boat & fuel consumption on a smooth lake is 2 MPG.   In rough water with hull pushed down (tabs down & prop all the way down) to keep the bow from slamming, you will get less than 1.5 MPG.  Its a heavy hull & under powered with the single 260 HP engine.
  [Tiara Open] High oil pressure readings Mydiamond 3 2,413 05-26-2025, 02:52 PM
  Fuel Tank Issue mcmahome 4 4,463 08-24-2020, 07:12 PM
  3100 fuel efficiency Coppifan 5 8,600 08-23-2020, 09:13 AM
Last Post: Chesfisherman1
  High Pitched Sound Bassman 1 2,757 08-24-2019, 10:35 AM
  Fuel Polishing NYMarine1 7 8,076 11-06-2015, 12:11 PM
Last Post: Babetoo
