Cleaning Brass Prop and Stainless Shafts
What is the best method to clean brass props?
Best method to clean stainless shafts?
They are attached to a boat dry docked.
Last year I found some 3M scotch brite stripping discs that attach to a drill. I used them on the rudders, shafts & props to clean off all the old built up antifouling & barnacle remnants. They work great, but of course you need to wear a respirator. I used a slightly softer disc on the stainless & I found my cordless drill didn't have enough RPM so had to run an extension for my corded drill.
http://tinyurl.com/kd4yzbp
I just use a wire brush on my cordless drill. It makes fast work of it.
Mark - Reely Nauti
Make sure to get a good clean area for your shaft zincs and hit them with a hammer slightly to get a good bond
  Seized Stainless Fasteners duchess 3 1,510 09-05-2024, 09:03 AM
Last Post: duchess
  cleaning teak&holly cabin floor OurHighLife 4 2,492 08-29-2023, 06:23 AM
  Cleaning seacocks honest mark 3 2,662 07-21-2022, 08:41 PM
  2003 Tiara 31 Open w/Cummins 6BTA 5.9 330HP Prop size alhalpern 1 1,923 06-29-2022, 06:29 PM
Last Post: Misdirection
  [Tiara Open] Cleaning the 50 amp cable CaptBrett 18 18,420 02-13-2022, 02:55 PM
Last Post: CaptRCA
