Westerbeke Generator no start
93 3100. My westerbeke 3cyl generator was running perfect. The aluminum exhaust piece that clamps to the exhaust manifold rotted and made it loud. A simple replacement and now I have nothing. Doesn’t crank over unless I jump the starter. Only wiring involved is the overheat sensor. I musta knocked a wire off something with my fat ass.
I did the same thing last year. I knocked one of the sensor wire off. I dont remember which one but I would just go through and pull and clean the terminals. You should be able to get info from westerbeke in marblehead MA. They are very helpful and a good resource for your genset.
Ya I kinda figure something like that
Check the stopping solenoid too. Pull (or is it push?) that little piston all the way in or out and try it. Might need to hold it by hand and start it at the Gen to test.
(02-04-2024, 08:43 AM)MC1600 Wrote: Check the stopping solenoid too. Pull (or is it push?) that little piston all the way in or out and try it. Might need to hold it by hand and start it at the Gen to test.
The what? Where is that located?
It was a simple fuse. I looked at it 3-4 times. Looked good but a meter proved otherwise. Thanks
  2001 3100 open generator runs but doesn't generate electricity lakesidevu 5 2,935 11-14-2025, 01:01 PM
  2006 3600 Sovran Generator Battery location Final Pursuit 0 887 08-09-2025, 07:49 AM
  [Tiara Open] Westerbeke 5.0 BCDB jsheerin 3 2,383 04-26-2025, 02:00 AM
Last Post: Roweje
  Westerbeke gas generator Sandy Bottom 4 4,889 09-01-2020, 09:22 AM
Last Post: Misdirection
  Generator Usage Jayr 4 4,722 08-17-2020, 09:47 AM
Last Post: Jayr
WTB Tiara Coronet (1997-2007)
Last Post: JaviAirstream
Today 02:09 PM
Today 10:03 AM
Today 09:58 AM
11-18-2026 05:48 PM
Last Post: joshuawhite
11-18-2026 02:48 PM
