Replicating Tiara's Modified Sump Box
I thought I would post this in case anyone else is facing the same issue.  I have a 2003 3500 Open.  The pump in my Rule Sump Box stopped working.  I cleaned the box out but was not able to get the pump operating again so I decided to replace the entire box with a new one.  That is when I figured out that Tiara had modified the box to accommodate a couple extra plumbing lines.  Here is what was needed to replicate the modification on my boat:
Rule 98A shower drain kit;
7/8" spade bit (this new hole accommodates the hose from the AC condensate line; that hose comes with its own fitting that could be re-used);
1 3/8" hole saw;
Sea Choice plastic thru-hull hose fitting (part 18091); and
Permatex Gasket Maker, teflon string and marine silicone sealant.
The thru-hull fitting being added accommodates the shower drain. The hose from my shower drain was stretched a bit such that I was getting some drips even with the double worm gear clamps.  I beefed up the new thru hull flange with some Permatex liquid gasket maker and teflon string to stop the leak.
Thumbnail(s)
[-] The following 2 users Like ddfour1's post:
GMahanna (12-09-2020), reeltimebrad1 (01-22-2018)
Thank You for the information. I am sure it will come in handy for others. In the middle of going through all my systems this year.
  Factory Tiara Classic Hardtop jmk 33 48,295 06-08-2025, 09:22 AM
Last Post: Craig Dunlop
  43 Tiara Sportsfisherman Forward Deck Repair furiarte 5 3,257 09-01-2023, 10:06 AM
Last Post: Jack Aperio
  2005 Tiara 3800 stereo / amp wiring access Hemlock_SF 0 1,310 04-16-2022, 09:46 AM
Last Post: Hemlock_SF
  2005 Tiara 3800 bait tank install Hemlock_SF 3 2,751 03-30-2022, 10:49 PM
  1993 Tiara 3300 L-shaped passenger seat CaptChuck 2 3,177 12-20-2021, 01:00 PM
Last Post: kwerner
Replicating Tiara's Modified Sump Box00
