2008 sovran 3900 Steering Hub / Drive by Wire
Hello
My sovran normally has little resistance to steering inputs.  The Hub lock on autopilot.   However lately it   get very stiff and I have to work to steer the boat.     THe Hub is not mechanically connected to the steering as this is drive by wire.
I'm thinking this is an electronic issue inside the hub.  Any deas?
Vince
(03-20-2022, 06:20 AM)VPelliccia Wrote: Hello
Vince
Are you saying while autopilot is engaged? What autopilot? It’s my understanding that the autopilot must allow the steering inputs and relax the electronic resistance. On my Garmin it will specifically show on the screen that this is activated if I steer. If it’s stiff otherwise when the autopilot is not in use, there are known issues with IPS and stiff steering caused by a number of potential problems. HCU and steering knuckles are two that I’m aware of.
  2008 36 Open with Cummins Dosplays Afarneti 1 5,087 03-04-2026, 05:56 AM
Last Post: ken9090z
  [Tiara Open] Loose parallel wire behind ignition plate 1996 Tiara open Mydiamond 0 5,103 08-14-2025, 08:05 PM
  2006 3600 Sovran Final Pursuit 3 5,690 08-09-2025, 02:35 PM
Music Tiara 44 Sovran Amplifier tburling1958 3 3,271 04-01-2022, 10:05 PM
Last Post: Folkvord
  2006 Sovran 3600 radar placement sluggo 5 7,648 07-19-2016, 03:19 PM
Last Post: Uhehner
2008 sovran 3900 Steering Hub / Drive by Wire00
