2006 Sovran 3600 radar placement
my Sovran has an e120 raymarine with gps only.  I would like to add an open array radar to it.  To my knowledge there are no qualified installers within 100 miles of me, so who ever I get I figure I am going to have to coach a little.  That said, where on the top would you recommend placing the open array unit??  I guess I have to be careful relative to the hatches.  Anyone know or have it done??  Is there a schematic from Tiara about where to place this??  TIA.
Just my 2 cents.  You don't want the radar beam to hit the GPS antenna and you want to mount the unit at about a 5 degree down angle to account for the bow rising when you are running.  And DON'T cut the cable in order to snake it through a pipe.   Capt  George
If its anything like the 39 Sovran that we had previously, or our current 42 Open, there should be an access panel on the under side of the hard top in the center.  You will center the new radar here...  Tiara generally has some sort of channel that you will then run the cable through.  If you're lucky, there will even be lines in there to pull the new cable.
max
(07-19-2016, 10:26 AM)Uhehner Wrote: Just my 2 cents.  You don't want the radar beam to hit the GPS antenna and you want to mount the unit at about a 5 degree down angle to account for the bow rising when you are running.  And DON'T cut the cable in order to snake it through a pipe.   Capt  George
if the Radar is above the GPS antenna, would this be acceptable placement?  to obtain a 5 degree down angle, are there shims available?  TIA
(07-19-2016, 10:30 AM)Maxwell Wrote: If its anything like the 39 Sovran that we had previously, or our current 42 Open, there should be an access panel on the under side of the hard top in the center.  You will center the new radar here...  Tiara generally has some sort of channel that you will then run the cable through.  If you're lucky, there will even be lines in there to pull the new cable.
max
thanks!!  is it centered left/right as well as front/back?
If its what I'm thinking, you would center it front/back and side/side within the opening on the underside of the hardtop.  You want to be able to access the bolts on the underside in order to back plate it etc.
max
max
If the beam is above the GPS antenna that's OK. You just don't want it to shine on the GPS and fry the electronics. For shims I have seen nuts and washers on the rear mounting bolts.  Capt. George
  2000 3500 Express Raymarine c120 Radar Replacement - Ohio River JMGCINCY2023 5 8,521 09-02-2025, 10:06 AM
Last Post: sluggo
  2006 3600 Sovran Final Pursuit 3 5,647 08-09-2025, 02:35 PM
  Radar error code 6, autopilot ECU circuit overload d5dekeyser 2 2,121 06-30-2024, 08:58 PM
  [Tiara Open] Advice on Radar/electronics Fuggly 0 2,226 01-07-2024, 07:38 PM
Last Post: Fuggly
  Garmin Radar firstlight 1 2,212 06-28-2023, 12:57 PM
2006 Sovran 3600 radar placement00
