2001 3500 open with 7.4 Crusaders Prop's
Just bought a 2001 3500 open. Currently has 3 blade props. Looking to see who's running what and what would be the best props to run on this boat. 7.4 Crusaders. Thanks
You've got the best props on it unless you've added considerable weight to it like a 400 lb rib on the swim platform.
Thanks reeltimebrad. Just bought boat and saw they are three blade props. I have read that some owners are using four blade props. Im not sure of pitch. Plan on looking when boat is hauled for winter. Any help would be appreciated. Thanks
What do you see for speed and fuel burn with the 7.4's? Just curious.
I can only get 26 kts at 4000 rpm. 22 kts at 3300. Burning about 30 gal per hour.
I would think your WOT RPM's should be maxing out around 4400, depending upon water conditions and weight on board. You seem to be a little below that. First thing I would do is after the boat is hauled out, confirm the pitch and diameter of your current props. That should be listed on your survey as well, assuming you had one done. Then I would contact Tiara Customer Service and request what the original props for your boat were and compare.
Thanks Great idea.
  2001 3500 open, diesel exhaust flanges? North Star 4 1,201 02-24-2026, 08:55 AM
Last Post: North Star
  1989 33' Tiara Open - Bedding Question jgaudet2 2 1,851 12-21-2025, 10:02 AM
Last Post: jgaudet2
  2003 3100 Open cabin privacy curtain. Hilary 3 2,557 12-02-2025, 02:13 PM
Last Post: E-MAN
  2001 5200 Express knot@work 0 1,700 12-02-2025, 09:28 AM
Last Post: knot@work
  [Tiara Open] 2006 Tiara 42 Open Powered With QSM 11 675 hp - Thoughts ? DoctorM 5 3,633 10-20-2025, 09:05 AM
Last Post: DoctorM
2001 3500 open with 7.4 Crusaders Prop's00
