1999 Express 40 cockpit tables
My hydraulic system that operates the trunk and tables has died.  I need to manually lift the tables so that I can clean under and around the tables.  Can someone tell me how to disconnect the tables from the lift?
I would drop Tiara customer support a note. I think they have a service bulletin available for those tables. If they are like tables on the 5000 express the table base is a scissor lift attached to a jack screw assembly powered by a hydraulic motor. Not sure you can manually lift the tables without disconnecting the jack screw. And with the tables down I suspect it will not be easy to access. There should be service hatches accessible underneath but I think it would be difficult to work by feel.
I suspect your easiest path would to replace the hydraulic power unit. If you can find a name tag on the unit you may find a replacement pump out on the web. valves and solenoids should be reusable providing they all work. Otherwise Tiara may have a replacement in stock or tell you manufacturer information.
Good luck
I have a similar issue with the cockpit tables on my 96 4000E. But I was able to raise my tables to determine why the motors would not raise them. It took 2 guys to lift it manually and in my case the ACME nut and screw were no longer threaded together, the nut had spun off the end of the screw, released from the nut housing and is stripped so I am not able to reattach it to the screw or table nut housing.
So in my case since the nut was no longer attached and I was able to raise by lifting by hand.
I emailed Tiara and they only have the replacement parts for ACME Screw, they do not have a replace for the ACME nut which is the part that needs replacing for me. I have looked at Grainger and some other local machine shops and no luck finding a replacement. So I am not looking into re-tapping the threads in the nut. Finding a TAP and the ACME thread size has been the challenge. I just ordered a ACME screw pitch gauge....but at first glance the taps I will need to rethread look very $$ for a one time job.
Any ideas or experience with this repair on the tiara 4000E?
I am starting to think replacing the ACME screw config with a hydraulic cylinder might be a better way to go.
  2000 3500 Express Windshield Wiper Blade Replacements JMGCINCY2023 5 2,866 04-19-2026, 06:48 PM
  Tiara Express Battery Charger Replacement Svdb12@chartermi.net 0 650 09-07-2025, 11:19 AM
  2001 40 Express - Windshield Washer Will Not Stop bruce@bigrivergroup.com 1 719 09-02-2025, 06:19 PM
Information 2000 express 4000 fuel system questions... bman440440 2 1,230 07-23-2025, 08:19 PM
Last Post: bman440440
  [Tiara Coronet] Removing Cockpit Speakers Dave F 2 1,262 07-14-2025, 10:05 AM
Last Post: Dave F
1999 Express 40 cockpit tables00
