Crusader 454 will not go over 2800 rpm
#11
Sounds to me like it is going into limp mode. My 33 with LXI’s did this a couple of years ago. Temps were good, oil pressure was good. Only happened after cruising for more than 30 minutes or so. Long story short, my port transmission was very low on fluid and would get hot enough to trip the sensor causing the motor to go into limp mode.
[-] The following 1 user Likes Chadweiser's post:
Misdirection (08-06-2021)
#12
Thanks all.. electronic issue… 2 bad plugs and wires.
Replaced all plus cap and rotor.
Back to fishing…
[-] The following 2 users Like Mydiamond's post:
Chadweiser (08-25-2021), Misdirection (08-25-2021)
#13
I have a similar issue, max rpm is 3700. I went thru everything as previously mentioned. Engines sound great even at the lower wot. My compression is low, even but low. 115-118 across the board. My engines tho are 32 years old with roughly 2100hrs. They’ll be coming out for an overhaul this winter. Hope you have a simple fix
[-] The following 1 user Likes Lucky Dog 33's post:
Mydiamond (09-08-2021)
  [Tiara Open] 2003, 3100 with Twin Crusader 8.1L MPI Gas Engines jmdegraff 2 1,281 06-16-2025, 08:07 AM
  1997 Crusader 454 XLi Service Manuals TiaraTom 4 4,739 01-16-2025, 08:59 AM
Last Post: dthelen40
  [Tiara Open] Crusader gas engine crank but no spark Mydiamond 1 2,647 10-18-2023, 04:32 AM
Last Post: czarcone
  Crusader 8.1 mpi surges at running speed Betterdays123 13 16,803 06-28-2023, 09:57 AM
Last Post: Phil Lane
  Crusader Mechanic Needed North Florida 904polarized 1 1,861 03-27-2023, 04:41 AM
Last Post: 904polarized
Crusader 454 will not go over 2800 rpm00
