Threads: 5
I have a 3200 with what feels like 2 miles worth of power cables. I typically wrestle them in the compartment just to the left of the outside refrigerator. Obviously, with a boat this size, dedicated space for this is a premium.
My question......Has anyone come up with an easy way to store these cables? Secondly, how long do the cables really need to be? Mine have to be at least 50' long......which I've never had to use in the 10 years we've had the boat.
Threads: 12
Home Port: South haven,mi
Vessel Info: 2006 3200 0pen 8.1 crusaders
I coil them up and put them under my starboard fishbox right behind the muffler.
Threads: 8
10
Home Port: Port Canaveral, FL
3406E Cats
My 41 has the glendining reel and it is great. On my old boat i had 2 sets. One I always left at the slip and just disconnected it from the boat. The other I kept stored for overnighting at other marinas. That way I wasn't messing around with them if I didn't have to.
Threads: 5
Appreciate the responses. The reels look nice, but not sure where I could fit that on my boat.
I'll probably just go with shorter cables......and maybe dedicate that smaller fish box to it.
Threads: 9
4
Home Port: Daytona Beach, FL
Vessel Info: 2000 Tiara 3500 Open
Cummins 6bta -370
I have set up mine to 'hang' under the starboard side gunnel and only peel off what is needed. I would never switch to shorter cables as we make trips to the Bahamas and you never know how long of a cord you will need. I have had to peel all 50' off several times as the pedestal for my slip was not functioning, typical Bahamas. I used a starboard hangers for this, kind of like a water hose coil for your house only smaller profile. Keep them out of the way and I leave the connection on the boat connected, remove from the pedestal, coil, and away we go. If I had a photo I would post it but I don't at the moment.
Threads: 0
I use a splitter and just one cord which coils neatly on the floor in the transom door opening. The part that goes to the plugs runs along the gutter in the side of the cock pit. If you keep it clean, the white blends in and it is out of the way. You do need to manage your power usage. I agree with the advice to stay with 50 feet if you can. We keep the unused extra cord in the fish box.
Threads: 6
1
You can get a cable caddy west marine has them. Also check amazon.
