Changing impeller on Starboard 2900 Open??
Wow, I need to change the impeller on the starboard crusader on my 2900 Open. I can't see any way to reach it?
Has anyone done this, if so, how did you do it?
Thanks.
HarmoneE²
Tiara 3800 Open, Onset MA
I did it ! Had to remove the alternator.
Reached across and removed the adjustment bolt and the pivot bolt
And the hose from the u-tube then
The whole assembly can be moved
Into the center. Took about 3 hours
Total
HarmoneE²
I agree . I find when working on any of those parts its just as easy to remove ,fix and then reinstall . I even replace mounting hardware. While we are on that subject do you have problems with alternators loosening periodically.
No, however the raw water pump belt
Seems to get loose. I don’t think the
Impeller was bad ( still changed it ) I think it was the belt. Hardest part was tensioning the new belt. You can’t get two
Hands in there. I cut a board and braced it against the well and that did the trick keeping the tension on while I tightened the bolt
HarmoneE²
We have the same boat .... I'm in Marshfield Green Harbor Brewers or Safe harbors which ever you prefer.
[-] The following 1 user Likes Sallypops's post:
efontana (04-29-2019)
Got it!
[Image: BXjuEYu.jpg]
HarmoneE²
Are you in the water yet? If so did you have any issues?
(05-16-2019, 07:24 PM)Sallypops Wrote: Are you in the water yet? If so did you have any issues?
Yes, been in the water since April 15th. The biggest problem was the Marina oil change. They left the gasket
from the old filter and of course the new gasket, at 3200 RPM the gasket blew and 5 quarts of oil sprayed all over
the engine room, luckilly I shut the engine down immediately, after a huge cleanup, it's running great now.
HarmoneE²
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 2 293 10-05-2026, 11:57 AM
  38 open bathroom recessed light bulb twilson0929 3 542 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 425 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 833 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,463 05-22-2026, 06:41 PM
Changing impeller on Starboard 2900 Open??00
