Tiara Open water in fuel alarm
Hi there - I have twin cummins QSB diesels, 600 hrs and all was great. Off and on I've had the "water in fuel" alarms; I've bled the racors in the past and alarm went off. But it would come back off and on. Recently the port engine suddenly sounded "rough" and there was some smoke. It sounds like one or 2 cylinders not firing; but also the "water in fuel" is back and specifically that same port engine. I've bled the racors again, replaced them as well as the other fuel filters. Still sounds rough. Could it be coincidence on water in fuel and I've also got some injectors not working?
Any help / experience here is appreciated.
You need to join boatdiesel . com. It cost very little and those guys absolutely know diesels.
(08-11-2022, 05:34 AM)Sans Peur Wrote: You need to join boatdiesel . com. It cost very little and those guys absolutely know diesels.
thank you
  2000 3500 Express 6BT 5.9 Best Fuel Economy RPM's JMGCINCY2023 1 1,990 10-09-2024, 02:30 PM
  [Tiara Sovran] Anyone cleaned fuel vent flush mount Donaldjames 0 1,297 05-09-2023, 11:55 AM
Last Post: Donaldjames
  Tiara Coronet water tank fill problem d5dekeyser 1 1,821 06-07-2022, 08:26 PM
  Generator fuel supply and unnecessary auto-off robin.joshua 2 2,304 05-14-2022, 09:07 PM
  No alarm beep when turning ignition key 454 crusader gas engine Mydiamond 2 3,790 11-13-2021, 08:30 PM
