Breaker Amperage
Older 31, how to determine amperage of the DC breakers. Looking to add LED engine room lights and need to know what the breaker will handle.
Thanks for the help!
Do you hace the manual.for.the boat? It will.show them in that. If not, you are going to have to open the panel.and look on the breaker. There will be a sticker on each of them telling you the size.
As LED lights don't use a lot of current (amperage) I'd suspect 5 amps would more than cover it. How many LED lights are you going to install and what are the spec's regarding the lights (amperage). If the total draw is more than 5 amps Id go bigger. Also are you planning to connect other DC devices to the circuit... MAke sure the breaker covers all.... M2C
Thanks for the responses. I am sure you are correct that I have to pull the breaker to determine amperage, hoped it would say on the back.
The breakers are there to protect the wires, not the devices. The breaker should be sized based on the wire gauge and type.
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 1,341 07-15-2026, 08:06 AM
  Electric Breaker panel Jbuchsdvm 5 4,966 10-21-2024, 10:08 AM
  [Tiara Open] Push button breaker 12v replacement Mydiamond 2 1,660 09-28-2024, 09:01 AM
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 2 1,646 08-18-2024, 07:22 PM
  [Tiara Sovran] Windless Breaker 58 Sovran dave@lynchconboy.com 4 3,291 09-06-2022, 03:35 PM
Last Post: dave@lynchconboy.com
Breaker Amperage00
