Tiara Coronet Port engineer and electronics quit running at same time
My 2001 coronet with crusader engines. Today both started, pulled away from dock under full power. 60 seconds into trip port engine and electronics quit. Batteries seem fine just a bit low. Engine turns over - not the click of a low battery but port engine does not run but starboard functions as normal.
Did you try flipping the switch that parallels both batteries/engines?
(07-04-2026, 12:46 PM)Final Pursuit Wrote: Did you try flipping the switch that parallels both batteries/engines?
Yea I did and still no power. My charger shows an FAULT for battery 1….fuse or something more significant?
update:
Port lower Fuel Pump wire corroded and came free of the pump. Replaced Pump and now Engine is running fine.
However, unable to isolate the Garmin issue...no fuses blown. Only change before all this was adding the 24xd GPS puck to the NEMA 2000 backbone. The search continues...
  [Tiara Open] 2001 3500 Open no fuel to port engine??? wow 4 3,862 05-31-2024, 11:32 AM
Last Post: RMS
  Port light or port hole window lwaking dbruce222@gmail.com 5 4,303 05-25-2023, 01:15 PM
  New Electronics HELP for Sovran 45 Max5514 1 1,465 06-25-2022, 08:48 AM
  [Tiara Open] Access to Port Wiper Motor on 3800 Open Tony Saitta 3 3,446 04-09-2022, 02:48 PM
Last Post: rotellats@gmail.com
  36 open port light removal Renegade93 6 4,645 12-08-2021, 01:21 PM
Last Post: Dakota773
10-30-2026 06:10 PM
10-28-2026 10:32 PM
Last Post: Gustaf
10-28-2026 01:07 PM
