12 Volt under cabinet puck lights
        Looking to replace one of my under cabinet 12 volt puck lights (see photos) but can not find a brand or vendor name on the device.
Has anyone got a lead on the original manufacturer?
2005 36 Sovran
Cummings 6C-AT 480
Might be easier to replace the lamps. I swapped out the G4 halogens for LED and they're great. A bit less heat and the same out put.   Lamps aren't cheap, but cheaper than replacing the whole assembly, time too.
(09-25-2016, 05:02 PM)Dakota773 Wrote: Might be easier to replace the lamps. I swapped out the G4 halogens for LED and they're great. A bit less heat and the same out put.   Lamps aren't cheap, but cheaper than replacing the whole assembly, time too.
Agreed on switching to LEDs, but I failed to mention in my first post that I have one fixture that is cracked/broken and I was hopeful that I could find the exact replacement.
2005 36 Sovran
Cummings 6C-AT 480
My 2005 44 Sovran used both Imrta lighting and Cantilupi lighting.  Check with the factory if you can't find any info on the fixture.
(09-26-2016, 07:49 AM)TIARA44 Wrote: My 2005 44 Sovran used both Imrta lighting and Cantilupi lighting.  Check with the factory if you can't find any info on the fixture.
Thank you both for your assistance.  I was able to find the right part from Tiara.  For future reference:
Part # 3362290 LIGHT,BLACK SURFACE
$60.00 each
2005 36 Sovran
Cummings 6C-AT 480
$60.00 each
Thanks for sharing I am assuming that is Tiara part #?  did you ever find the make and model??
its always great when someone follows up about finding a solution.
(09-29-2016, 12:26 PM)sluggo Wrote: [Only registered and activated users can see links Click here to register]
 7950 Central Industrial Drive
Suite 106
Riviera Beach, FL 33404
   800 844 8593
       561 842 5704
2005 36 Sovran
Cummings 6C-AT 480
(10-03-2016, 12:50 PM)Outlaw Wrote: [Only registered and activated users can see links Click here to register]
Suite 106
   800 844 8593
       561 842 5704
thanks!
  DC Panel Volt/Amp Seclector Switch Replacement Peave 4 1,558 11-07-2025, 02:50 PM
  Tiara 3600 Courtesy Lights No Longer Available Roweje 0 1,039 11-10-2024, 09:17 PM
Last Post: Roweje
  [Tiara Open] Switch for Lights in steps on 2007 3600 Ope Roweje 0 906 06-15-2024, 07:50 PM
Last Post: Roweje
  [Tiara Open] 3100 Dash lights tatum051 3 5,669 07-20-2023, 05:47 AM
Last Post: MuskyHuntr
  [Tiara Open] Red led control panel lights out lakesidevu 0 1,379 06-22-2021, 01:05 PM
Last Post: lakesidevu
12 Volt under cabinet puck lights00
