Threads: 8
Home Port: Venice Florida
09-24-2016, 02:05 PM
(This post was last modified: 09-24-2016, 02:11 PM by Outlaw.)
Looking to replace one of my under cabinet 12 volt puck lights (see photos) but can not find a brand or vendor name on the device.
Has anyone got a lead on the original manufacturer?
2005 36 Sovran
Cummings 6C-AT 480
Threads: 14
2
Might be easier to replace the lamps. I swapped out the G4 halogens for LED and they're great. A bit less heat and the same out put. Lamps aren't cheap, but cheaper than replacing the whole assembly, time too.
Threads: 8
(09-25-2016, 05:02 PM)Dakota773 Wrote: Might be easier to replace the lamps. I swapped out the G4 halogens for LED and they're great. A bit less heat and the same out put. Lamps aren't cheap, but cheaper than replacing the whole assembly, time too.
Agreed on switching to LEDs, but I failed to mention in my first post that I have one fixture that is cracked/broken and I was hopeful that I could find the exact replacement.
2005 36 Sovran
Cummings 6C-AT 480
Threads: 6
1
Home Port: North East
Vessel Info: 2005 4400 Sovran
Cummins QSM-11 660HP
My 2005 44 Sovran used both Imrta lighting and Cantilupi lighting. Check with the factory if you can't find any info on the fixture.
Threads: 8
(09-26-2016, 07:49 AM)TIARA44 Wrote: My 2005 44 Sovran used both Imrta lighting and Cantilupi lighting. Check with the factory if you can't find any info on the fixture.
Thank you both for your assistance. I was able to find the right part from Tiara. For future reference:
Part # 3362290 LIGHT,BLACK SURFACE
$60.00 each
2005 36 Sovran
Cummings 6C-AT 480
Threads: 8
(09-29-2016, 12:26 PM)sluggo Wrote: (09-28-2016, 03:02 PM)Outlaw Wrote: (09-26-2016, 07:49 AM)TIARA44 Wrote: My 2005 44 Sovran used both Imrta lighting and Cantilupi lighting. Check with the factory if you can't find any info on the fixture.
$60.00 each
Thanks for sharing I am assuming that is Tiara part #? did you ever find the make and model??
its always great when someone follows up about finding a solution.
The light was manufactured by DRSA of Riviera Beach FL .
http://www.drsa.com/
7950 Central Industrial Drive
Suite 106
Riviera Beach, FL 33404
800 844 8593
561 842 5704
2005 36 Sovran
Cummings 6C-AT 480
