Bilge
I have a 1996 Tiara Express 40, on the port side below the engine I have water that collects along the engine support stringer running fore and aft. I do not understand why the water is collecting there and not draining to the lowest point in the boat (i.e. mid bilge area or aft bilge area). I feel there may be a plugged access hole which is trapping the water and not allowing it to drain properly. However, I cannot locate a hole for the water to drain through. Any insights is appreciated and how I can get this water to reach the mid bilge or aft bilge to be expelled by the bilge pumps.
I can't tell you where the water is coming from but I have owned a 2000 35 Open and now own a 2005 38 open and the compartment under the engines in these boats are designed not to drain fluid to lower parts of the boat. This to prevent any engine fluids from being pumped overboard. Anytime I clean the engines I use a wet vac to suck the water from under the engines. Hope this helps.
Thanks! That makes sense. Not a lot of water, but enough to drive me to wonder. Thanks again.
(07-26-2017, 02:10 PM)RidinHigh Wrote: I can't tell you where the water is coming from but I have owned a 2000 35 Open and now own a 2005 38 open and the compartment under the engines in these boats are designed not to drain fluid to lower parts of the boat. This to prevent any engine fluids from being pumped overboard. Anytime I clean the engines I use a wet vac to suck the water from under the engines. Hope this helps.
What do you clean the engines with?
I use a cleaner-degreaser in a garden sprayer ( the purple stuff). Spray it on everything, let it set for a few minutes and use a low-pressure pressure washer. Be sure to rinse everything well, than take a shop vacuum to remove the water from under the engines. This process is simple and has worked quite well for me. Careful not to get the cleaner in your eyes or on your skin. Good Luck!
[-] The following 1 user Likes Ridin'High's post:
bwoods94 (07-29-2017)
I have been thinking about this. How exactly do you clean the engines?
Never mind. Just saw the follow up post. LOL
  Water if forward bilge after rain lenoah 0 585 11-21-2025, 05:53 PM
Last Post: lenoah
  Keel bilge pump runs on 52 Sovran Salon during trips Knot On Call 9 2,767 08-21-2025, 08:28 PM
  43 open keel bilge vs mid bilge bnr@dur-a-flex.com 2 1,477 12-08-2024, 07:34 AM
Last Post: bnr@dur-a-flex.com
  [Tiara Open] Forward bilge wiring Mydiamond 1 1,150 09-19-2024, 11:54 AM
Last Post: ardoski14
  50/53 Coupe and Fly Owners Group-Rain Water in Bilge Sapphire 3 2,016 02-11-2024, 09:53 AM
Bilge00
