Tiara Sovran Taking on water when running
#11
Well I checked the muffler clamps and none were loose but non were tight either.  They are all now tight and i plan on running to Ft. Jefferson next weekend so I will find out if the problem has been solved.  I will post the results.  Thanks for everyone's advice
#12
I know someone that his boat had the same symptoms and the water was coming from a crack on the bilge... Try to dry your bilge and if you see water coming find out where is coming from... It could be a thru hull or a crack on the fiberglass. If you get a small amount of water stationary, this will increase as your boat is moving because you will increase the pressure under the boat.
#13
Well apparently it was the muffler clamps.  Ran 150 miles to Fort Jefferson from Stock Island and back with no water leak after tightening all the muffler clamps. Big Grin
[-] The following 1 user Likes 52Frankfort's post:
Misdirection (02-08-2022)
#14
Easy fix. Glad you found it.
  [Tiara Open] New To Me Tiara 36 Open Water System Question jayacarrion@gmail.com 2 1,219 08-29-2023, 05:30 AM
Last Post: bandnew
  Water around the shower sump robh19 3 1,190 01-01-2022, 07:21 AM
Last Post: Capt. Tom
  [Tiara Sovran] 2008 Sovran 3900 AC Raw Water Pump Relay location bbisland 1 1,244 12-21-2021, 10:40 AM
Last Post: Skipper747
  Height in water 3100 open Joeboch348 0 854 11-14-2021, 04:00 PM
Last Post: Joeboch348
  Fresh water tank Txcolor 5 2,147 08-19-2021, 07:31 AM
Last Post: mggilmorern@gmail.com
Taking on water when running00
