Pull the hatches out of the boat and follow the instructions below to install new lens and gasket. Rebed the hatches with 3M 4200. Just did all three of mine. Find a local plastic supplier and have them cut the new lens and ask them to install it.
Parts come from Pompanette LLC, name and number below.
myles
Good Morning,
The serial numbers you provided came back to the following hatch models:
97028846 C193-STD-A
97027019 C191-STD-A
97029770 C191-STD-A
The C193 takes 6.33 feet of gasket P100-52.
The C191 takes 5.31 feet of gasket P100-52.
As P100-52 is sold by the foot I would recommend that you purchase 7 feet for the C193 and 6 feet for each of the C191's. This gasket is pretty readily available at most local marine hardware stores.
To re-bed the acrylic after you are able to source new acrylic near you, you will need GE ULTRAGLAZE, in black - SSG4000 (our part number P100-75). Again, this should be readily available at most local marine hardware stores. Or, if you would like, you can purchase direct through us. The gasket and silicone would ship from New Hampshire in 3-5 business days if you choose to order direct. I have added an order form if you choose to do this, or you can call in to customer service and order over the phone.
Our Pricing:
P100-52 $7.00 per foot.
P100-75 $39 per tube 1 tube =~2 hatch lenses
Kind Regards,
Stephanie D. Allen
Commercial Sales Manager
Pompanette LLC
73 South West Street
Charlestown, NH 03603
Tel: 603-826-5791
Fax: 603-826-4125
s_allen@pompanette.com
www.pompanette.com
INSTALLING REPLACEMENT LENSES IN BOMAR HATCHES
TOOLS: replacement lens
tube of silicone (GE Ultra Glaze)
old spoon
old butter knife or hanger
masking tape
blunt tool
1. Cut away old silicone and remove old lens.
2. Place a two-inch strip of masking tape around the top/outside of hatch lid in order to make the removal of excess silicone less difficult.
3. If you have a cast hatch disregard this step. If you have an extruded hatch and wish to replace your gasket, do so now, making sure to place lip of the gasket on top of the flange (the underside of the lens will sit on this portion of the gasket).
4. Peel off the paper on the underside of the lens.
5. Place a moderate bead of silicone on the flange and any crossbars where the lens will set.
6. Float the lens into the silicone bead.
(If your replacement lens has holes in it for your latch dogs, place the holes away from the hinge. Allow a 1/8” space between the front edge of lens and the frame so your handles will be properly aligned. If your replacement lens does not have holes in it simply center the lens in the silicone.)
7. After the lens is floated, apply a generous bead of silicone in the gap between the edge of the lens and the frame.
8. Using the back side of an old spoon, place the tip in the silicone at 45 degrees and trowel off any excess silicone.
9. Check for air bubbles (swelling in the silicone). To remove air bubbles; drag an old butter knife through the swollen area three inches before and after the swollen area. Apply a new bead of silicone to the disturbed area and trowel off excess silicone with your spoon.
10. Allow the hatch to sit for two days.
11. Peel off the masking tape and lens paper carefully use a blunt tool to remove any silicone, being careful not to scratch the lens or the hatch frame.
12. The silicone will be totally cured in 7 days.
REPLACING GASKET ON BOMAR HATCHES AND PORTS
ADHESIVE BACKED GASKET
(part numbers P100-53, P100-51, P100-52, P3000-20, P3000-21, P3000-22)
1. Pull out old gasket and using a sharp metal object (knife, awl, narrow chisel) scrape out all old adhesive. It is critical that all the old adhesive be removed.
2. Wipe down the gasket area with Isopropyl Alcohol. Use only Isopropyl Alcohol.
3. Starting near a hinge, pull back tape cover and apply gasket. After gasket is installed around perimeter, carefully cut gasket to length forming a butt joint. Using any new tube of superglue, cement butt joint being careful not to get superglue on the lens. Allow glue to set for five minutes.
4. Carefully go back and apply pressure the entire gasket. This step is extremely important. Pressure is needed to assure proper adhesion of the tape.
LIP GASKET
(part numbers P2000-25, P2000-26, P2000-09)
1. Pull out all old gasket.
2. Starting near a hinge, gently push the lip of the gasket into the space between the lens and extrusion.
3. Carefully cut gasket to length forming a butt joint.
4. Pull out two inches of gasket either side of joint. Superglue joint together. Be careful not to get superglue on the lens. Allow glue to set for five minutes.
5. Push gasket joint into cavity.
6. Apply a drop of glue in four corners as shown in the diagram below. (the gasket shown below is for demonstration, it does not represent all gaskets)
