Crusader 8.1 mpi surges at running speed
2004 Tiara 3200 crusaders 8.1 mpi
While on my last cruise I was traveling at 3200 rpm and my port engine started to surge periodically.
Every so often it would surge to a few rpm more the go below and back to 3200.
Engine oil pressure and temps never faltered. Good the whole time.
At one point I increased throttle but the engine would not increase throttle.
Upon return to port I powered down to 1000 rpm for a few minutes.
Then brought her back up to 3800 to get on plane, and she responded normally.
Any thoughts on this?
Fuel filters were new this year and all routine maintenance has been done.
Betterdays
First guess - bad plug, coil or injector.  Sounds like one cylinder is dropping out. Also do a check of the error codes to see if it's an electronics problem. There was a recall years back for the camshaft position sensor but 2004 should be the new type. You will need a good tech to check the spark plug voltage on each cylinder and one with a laptop to read out ALL the computer information.  Capt. George
(09-08-2015, 07:01 PM)Uhehner Wrote: First guess - bad plug, coil or injector.  Sounds like one cylinder is dropping out. Also do a check of the error codes to see if it's an electronics problem. There was a recall years back for the camshaft position sensor but 2004 should be the new type. You will need a good tech to check the spark plug voltage on each cylinder and one with a laptop to read out ALL the computer information.  Capt. George
Thank you Capt George
It sounds like you don't think it's fuel related at all?
What spark plugs do you recommend?
Also, where do I look on the engine for the year and model?
I said camshaft position sender. It's the crankshaft position sender that had a recall.  My mistake.
The recall was by serial number
2001 S/N 610002 - 610892
2002 S/N 62001 - 621065
2003 S/N 63001 - 630247
There is also a wiring harness recall and a fuse block modification for the same S/N's
The engine ID should be on the stbd. side and forward of the top of the exhaust manifold.
The plugs should be DENSO / TJ14R-P15
or
AC 41-933 ( I got these from their Ft. Lauderdale distributor Jerry's Marine 954-525-0311 )
Crusaders Customer Service guy is Mike Genna   803-345-1337 X133
A great guy with all the answers.
Hope this helps, Capt. George
I am having a similar issue with fluctuating RPM(s) on one engine (Crusader 8.1MPI - 2006) after running for abt 3 hours at cursing speed, 3200RPM(s). No fluctuation at lower RPM(s). The problem does not repeat after engine runs at lower RPM(s) or is shut down for a period of say one hour or more. Engine temp and oil pressure remain excellent at all times. Fuel for both engines is sourced from one tank. All fuel filters replaced each season (65-75 hrs). My suspicion is that it is electronic rather than fuel related - possibly related to heat in the engine room (?). Did you find a solution to what seems to be a similar problem ? You reply will be much appreciated. Thanks.
On my 2004 Tiara 3200 the problems was fixed by cleaning the emergency fuel cutoff valves.  There are 2 valves that shut the flow of gas in an emergency.  One on each engine connected to the fuel supply. They are located in the engine room aft.  They are very high and cannot be seen without being in the room in between the engines.
Mine were clogged with a shellac like substance that was impeding the flow of fuel.
I had a great mechanic who was very good at problem solving.  This was the last place he looked and was surprised at the amount of buildup within the valves.  They are similar to solenoid valves(small) 2”x2”.
They did not need replacement, only cleaning and it solved my problem.
Good luck!
Email me if you have further questions.
Hotwheels996@yahoo.com
Mike
[/quote]
(10-17-2019, 02:30 PM)Betterdays123 Wrote: On my 2004 Tiara 3200 the problems was fixed by cleaning the emergency fuel cutoff valves.  There are 2 valves that shut the flow of gas in an emergency.  One on each engine connected to the fuel supply. They are located in the engine room aft.  They are very high and cannot be seen without being in the room in between the engines.
Good luck!
Mike
[/quote]
The shellac is from the inside of your fuel tank. Tiara will tell you it's from using ethanol fuel. Regardless I had to add fuel strainers on the ends of my pickups in the tank itself to get all the debris from plugging up my filters. Getting it all out of the tank would be a huge undertaking. If you pull the inspection plate off the top of your tank and use a flashlight to look into the bottom of the tank you'll be amazed at all the little stringers of loose resin from the tank just waiting to get sucked up.
(09-09-2015, 03:02 PM)Uhehner Wrote: I said camshaft position sender. It's the crankshaft position sender that had a recall.  My mistake.
or
I was just reading some old post here.  I agree, Mike was a good guy and helped me out of a jamb one time.  Sadly, the last time we called Cursader (summer of '18 or '19)  they tell me Mike had passed away.  How sad.
Can anyone provide a picture of the emergency fuel cutoff valve?  I'm beyond desperate.  I've been trying to buy a 2005 3600 Sovran since June of this year but with the port engine experiencing the same issue I cannot get a complete survey for finance and insurance purposes.  My last thought is try to get the current owner to let me try to find and fix the problem.  I live on Clear Lake south of Houston and we are having a heck of a time getting a good mechanic on the boat who will stick with it until the issue is found and resolved.
Good luck!
Mike
[/quote]
They are located on the bulkhead behind the engine usually before any filters and have wires going to them. Just follow the fuel line from the tank. Sorry I don't have pics.
  [Tiara Open] Raw fuel smell while running WOLFDAWG71 3 1,409 11-19-2025, 07:43 PM
Last Post: Joeboch348
  Engine shut off while running Mydiamond 1 887 08-10-2025, 07:51 PM
  [Tiara Open] 2003, 3100 with Twin Crusader 8.1L MPI Gas Engines jmdegraff 2 1,272 06-16-2025, 08:07 AM
  1997 Crusader 454 XLi Service Manuals TiaraTom 4 4,726 01-16-2025, 08:59 AM
Last Post: dthelen40
  [Tiara Open] Crusader gas engine crank but no spark Mydiamond 1 2,642 10-18-2023, 04:32 AM
Last Post: czarcone
Crusader 8.1 mpi surges at running speed00
