TV Not working on the antenna
I installed new digital TVs on my 36 Sovran 2 years ago. They worked fine on the antenna and cable up until this weekend. When switching to antenna both on the TV and the A/B switch I do not get reception. Has anybody had a similar problem and found a solution. I am thinking I have either a bad A/B switch or antenna.
Do you get reception when plugged into cable, but not antenna? If this is the case, then I would bet your A/B switch is ok.
Do you know if you have a passive TV antenna or a powered antenna? Powered have boosters in them and usually have a light on the antenna when powered up (little red or green LED). My guess is your antenna is either bad, or you lost power if it is a powered antenna.
Thanks Chris. I t is a powered antenna. I will check it when I am on the boat this weekend
  2019 Tiara 34 LX stereo not working Bud Dieselman 1 1,701 10-01-2026, 07:47 PM
Last Post: icloud
  TV ANTENNA alcord 9 12,583 09-28-2020, 01:01 PM
Last Post: jhhall
  [Tiara Open] GPS Antenna for IPad? MichFan 6 6,340 07-24-2020, 11:39 PM
Last Post: MichFan
  Garmin Electronics not working IrvingVet 3 4,838 07-21-2014, 12:59 PM
Last Post: IrvingVet
TV Not working on the antenna00
