Tiara Open 1988 Crusader original alternator - What is need to change to AGM batteries ?
Spring project is to add a new onboard charger, isolator, and house bank.
Are the stock 1988 Alternators compatible to charge AGM Batteries?
If not, anyone has a link to what is needed to upgrade them?
[Image: NBvUYCDdQEqZfboL8]
AGM batteries prefer a low charge rate but if you don't frequently run down the batteries and use the engine alternators to charge back up you should be ok with OEM alternator. Set the charge rate accordingly on your house charger and you should be good.
ardoski14 (02-27-2020)
  alternator waycamp 2 1,215 04-06-2026, 10:36 AM
Last Post: waycamp
  1988 3300 Open - Voltage drop when lowering engine hatch or honking horn Pluto 3 1,279 03-24-2026, 09:46 AM
  [Tiara Open] 1994 3100 Open Number of Batteries Duke 3 3,262 01-27-2024, 03:33 PM
Last Post: Joeboch348
  [Tiara Open] Open 4100 change from AGM to Lithium? Clarky98 2 2,106 07-10-2023, 11:14 AM
Last Post: Clarky98
  [Tiara Open] 3100 Open 7.4 Gas Crusader Alternator Question eric_nelson 3 3,694 10-04-2022, 07:35 PM
Last Post: eric_nelson
1988 Crusader original alternator - What is need to change to AGM batteries ?00
